Ga door naar hoofdinhoud
Dell Inspiron 15-7537 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: stap 1, afbeelding 1 van 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: stap 4, afbeelding 1 van 2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: stap 4, afbeelding 2 van 2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Jean Whitmore
972 Reputatie
7 handleidingen geschreven
Cal Poly, Team 18-2, Maness Winter 2015 Lid van Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 3,419
