Ga door naar hoofdinhoud
Dell Inspiron 15-7537 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: stap 1, afbeelding 1 van 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
    As it is not clearly visible in the picture: You should start to open the base cover at the screen side, to avoid breaking the plastic guides of the base cover. A flat dough scraper is a pretty good tool for that.
    David Jatzke - Antwoord
  4. Dell Inspiron 15-7537 Keyboard Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
    These instructions look as if you ground the board first and then remove the battery.
    I think it should be the other way round. First, remove the battery. Secondly, ground the board.
    Yuri Kalnishkan - Antwoord
  6. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: stap 6, afbeelding 1 van 1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  7. Dell Inspiron 15-7537 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  8. Dell Inspiron 15-7537 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  9. Dell Inspiron 15-7537 Keyboard Replacement: stap 9, afbeelding 1 van 3 Dell Inspiron 15-7537 Keyboard Replacement: stap 9, afbeelding 2 van 3 Dell Inspiron 15-7537 Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Take the keyboard off the palm rest assembly.
    I had problems open and close the clips for the Keyboard-cables. ^^ Any tips how to open and close? Thanks in advance.
    Marco Wolfgarten - Antwoord
Conclusie
11 andere personen hebben deze handleiding voltooid.
Jean Whitmore
984 Reputatie
7 handleidingen geschreven
Cal Poly, Team 18-2, Maness Winter 2015 Lid van Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Leden
8 handleidingen geschreven
3 opmerkingen
Great guide, thanks for the help!
Patrick S - Antwoord
Thanks It’s Useful
ahmed omar - Antwoord
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 26
Altijd: 6,587
