Ga door naar hoofdinhoud
Inleiding
Because the model device does not have a hard drive, this is not a replacement guide, but merely a prerequisite guide for other removal guides.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Use a spudger to remove the base cover from the rest of bottom cover.
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. The model device did not come with a hard drive. However, you will need to remove the hard drive to proceed. Please remove the hard drive following the steps on page 16 of the official Dell Inspiron 15-7537 manual.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Jean Whitmore
960 Reputatie
7 handleidingen geschreven
Cal Poly, Team 18-2, Maness Winter 2015 Lid van Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Leden
8 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 6,635
