Inleiding
By using this guide, you will learn how to remove the back base cover of the computer, which is needed to access the interior of the laptop for the rest of the repair guides.
Wat je nodig hebt
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Één andere persoon heeft deze handleiding voltooid.
