Ga door naar hoofdinhoud
Dell Inspiron 15-7537 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: stap 1, afbeelding 1 van 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Battery Replacement: stap 5, afbeelding 1 van 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abby Schmiedt
226 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-2, Maness Winter 2015 Lid van Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 74
Altijd: 6,483
