Inleiding
Laptop speakers are usually very susceptible to damage because they’re sensitive to water and any other small particles that manage to get inside it. This guide will help you replace the speakers of the Dell Inspiron 15-5567. It is a relatively easy replacement. You'll need to take the back cover first as a prerequisite, and the two speakers are located on the top right and left. Please be careful not to press hard on the speaker cones as it’s susceptible to damage and rupture.
Wat je nodig hebt
Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
Remove two M2x4mm screws using the same screwdriver.
Remove the screws that secure the battery bracket to the system board and palm rest and keyboard assembly.
Remove the screw that secures the battery to the palm rest and keyboard assembly.
Remove the cable by using the blue plastic opening tool.
Lift the first speaker gently and remove it.
3 andere personen hebben deze handleiding voltooid.
