Ga door naar hoofdinhoud
Dell Inspiron 15-5567 Speakers Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Dell Inspiron 15-5567 Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 3 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: stap 1, afbeelding 2 van 3 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Speakers Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-5567 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Speakers Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15-5567 Speakers Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15-5567 Speakers Replacement: stap 3, afbeelding 3 van 3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the battery bracket to the system board and palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Speakers Replacement, Removing the Battery Bracket: stap 5, afbeelding 1 van 1
    • Lift and remove the battery bracket.
  6. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screw: stap 6, afbeelding 1 van 1
    • Remove the screw that secures the battery to the palm rest and keyboard assembly.
    • Note the location of the screw that secures the battery to the palm rest and keyboard assembly.
  7. Dell Inspiron 15-5567 Speakers Replacement, Lifting the Battery: stap 7, afbeelding 1 van 1
    • Lift the battery off the palm rest and keyboard assembly.
  8. Dell Inspiron 15-5567 Speakers Replacement, Speakers: stap 8, afbeelding 1 van 3 Dell Inspiron 15-5567 Speakers Replacement, Speakers: stap 8, afbeelding 2 van 3 Dell Inspiron 15-5567 Speakers Replacement, Speakers: stap 8, afbeelding 3 van 3
    • Remove the cable by using the blue plastic opening tool.
    • Lift the first speaker gently and remove it.
  9. Dell Inspiron 15-5567 Speakers Replacement: stap 9, afbeelding 1 van 1
    • Lift the other speaker gently and remove it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 967
