Ga door naar hoofdinhoud
Dell Inspiron 15-5567 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 15-5567 Battery Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 15-5567 Battery Replacement: stap 2, afbeelding 3 van 3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 15-5567 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-5567 Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 15-5567 Battery Replacement: stap 5, afbeelding 2 van 2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Saaed Chaudhry
382 Reputatie
2 handleidingen geschreven
Één opmerking
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 63
Altijd: 7,616
