Ga door naar hoofdinhoud
Dell Inspiron 15-5565 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5565 Wireless Card Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Wireless Card Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 15-5565 Wireless Card Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 15-5565 Wireless Card Replacement: stap 2, afbeelding 3 van 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: stap 3, afbeelding 1 van 2 Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Wireless Card Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-5565 Wireless Card Replacement: stap 4, afbeelding 2 van 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: stap 5, afbeelding 1 van 2 Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: stap 5, afbeelding 2 van 2
    • Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
    • Slide the bracket to remove it.
    • Disconnect the two cables from the wireless card.
  6. Dell Inspiron 15-5565 Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Slide out the wireless card to remove it from its slot.
Conclusie
Shayne Cola
181 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 109
