Ga door naar hoofdinhoud
Dell Inspiron 15-5559 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-5559 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 3 van 3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 15-5559 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kyla Ward
580 Reputatie
4 handleidingen geschreven
Baylor, Team S5-G5, Williams Spring 2018 Lid van Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Leden
5 handleidingen geschreven
2 opmerkingen
The blue part came off is that important?
walterandradeconde - Antwoord
can i put this in a harddrive enclosure?
chiggly 123 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 42
Altijd: 5,241
