Inleiding
If your files are corrupted or you see the blue screen of death you might have a faulty RAM. The RAM is an acronym for Random Access Memory which is where data currently in use are kept. This guide will show you how to replace a faulty RAM.
Wat je nodig hebt
Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
Take a spudger and wedge it between the panel and the base of the device.
Push down on the spudger until you hear a click sound.
Slide the spudger along the panel and continue to push down until the panel is completely detached.
Remove the panel.
Locate the two RAM cards.
Using your finger, pull the two small pins back from the RAM causing it to pop up.
