Ga door naar hoofdinhoud
Dell Inspiron 15-5558 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 15-5558 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 2 van 3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 15-5558 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 15-5558 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Adam Lourenco
775 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 4,734
