Ga door naar hoofdinhoud
Dell Inspiron 15-5552 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5552 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Battery Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-5552 Battery Replacement: stap 4, afbeelding 2 van 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 247
