Inleiding
This is a guide to show you how to replace the Dell Inspiron 15-5548 Wi-Fi chip. Make sure that the laptop is unplugged and powered off before beginning this procedure.
Wat je nodig hebt
Use a Phillips #00 screwdriver to unscrew both bottom cover screws, and remove the bottom cover.
To reassemble your device, follow these instructions in reverse order. When inserting new chip make sure it pops up when not secured by the screw.
