Ga door naar hoofdinhoud
Dell Inspiron 15-5547 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
    • Lift the keyboard from the top and gently detach it from the bottom end.
    • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
  2. Dell Inspiron 15-5547 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-5547 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
    • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
    • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Faiq Huzir
121 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G3, Harley Summer 2019 Lid van IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 839
