Ga door naar hoofdinhoud
Dell Inspiron 15-5547 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
Conclusie
Nicholas Nafziger
266 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G2, Harley Fall 2019 Lid van IUPUI, Team S1-G2, Harley Fall 2019
IUPUI-HARLEY-F19S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 1,253
