Inleiding
The fan is important for helping keep the internals of your laptop cool and protect it from overheating. Learning to uninstall and reinstall your fan will help you keep the internals of your laptop safe from damage.
Wat je nodig hebt
Flip the laptop on it's top and lay to a rest position.
Using the Phillips J0 screwdriver, remove the two indicated screws.
Use the spudger to carefully remove the back cover to get into the internals. Stick the spudger into the slot indicated in the photo by the marker.
Pry up from the slot, then pry up around the sides of the panel. The panel can then be removed by lifting the side with the slot and puling in that direction.
Start by removing the white ribbon cable. Lift up the black tab indicated by the red marker to disconnect the ribbon cable from the connector. Be careful while removing the ribbon cable, as it will possibly be taped to the fan.
Één opmerking
hola tengo un problema con mi pc, porque hay un cable que se calienta mucho y no se a que se debe.
