Ga door naar hoofdinhoud
Dell Inspiron 15-3558 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-3558 Hard Drive Replacement, Remove battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over. With the battery side facing you, push the latch to the right.
    • Lift the battery. You're done!
  2. Dell Inspiron 15-3558 Hard Drive Replacement, Remove disc drive: stap 2, afbeelding 1 van 1
    • Remove the single tiny Philips screw securing the disc drive.
    • Slide the disc drive out.
  3. Dell Inspiron 15-3558 Hard Drive Replacement, Remove bottom screws: stap 3, afbeelding 1 van 1
    • Remove the nine long Philips screws securing the bottom cover.
    • Remove the three small Philips screws securing the bottom cover.
  4. Dell Inspiron 15-3558 Hard Drive Replacement, Remove keyboard & palmrest screws: stap 4, afbeelding 1 van 3 Dell Inspiron 15-3558 Hard Drive Replacement, Remove keyboard & palmrest screws: stap 4, afbeelding 2 van 3 Dell Inspiron 15-3558 Hard Drive Replacement, Remove keyboard & palmrest screws: stap 4, afbeelding 3 van 3
    • Flip the laptop right-side-up and open it.
    • Use a spudger on each of the five keyboard clips.
    • Lift the keyboard slowly, and then remove the cable from the connector.
    • Remove the five medium-length Philips screws.
  5. Dell Inspiron 15-3558 Hard Drive Replacement, Remove HDD caddy: stap 5, afbeelding 1 van 1
    • Remove the two screws securing the HDD caddy to the palmrest.
    • Remove the ZIF cable from the connector.
    • Lift the caddy.
  6. Dell Inspiron 15-3558 Hard Drive Replacement, Remove HDD: stap 6, afbeelding 1 van 1
    • Remove the four screws securing the HDD to the caddy.
    • Remove the SATA-to-ZIF connector from the hard drive.
    • You're done!
Conclusie
9 andere personen hebben deze handleiding voltooid.
Joseph Sctbunio
7.416 Reputatie
42 handleidingen geschreven
3 opmerkingen
Good guide except step 2 would be better if it said “remove optical drive” or “remove CD/DVD drive”.
mt_braun - Antwoord
I was getting suspicious wether or not my laptop wardrobe replacement caused keyboard function loses (first F3, Caps lock, Left shift, Tab, second comes X key and now W key). Nearly all the keys other than the W key is rarely used and the method of hard drive removal shown in this web seems to support that idea too
Sirius K - Antwoord
BIG omission after step 4. this guide fails to tell you how to remove the entire back of the laptop. That is doable, if you read the comments for step 4. but pictures would have been very helpful. However, there were two screws in the battery holding compartment which I had to remove, not one.
tom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 108
Altijd: 22,113
