Ga door naar hoofdinhoud
Dell Inspiron 15-3543 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-3543 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 15-3543 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Conclusie
Één opmerking
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 1,036
