Ga door naar hoofdinhoud
Dell Inspiron 15-3531 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 2 van 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 3 van 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 15-3531 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 15-3531 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 15-3531 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Conclusie
Kody Dahlke
742 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G5, Leahy Spring 2018 Lid van USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 32
Altijd: 1,119
