Ga door naar hoofdinhoud
Dell Inspiron 15-3521 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: stap 1, afbeelding 1 van 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: stap 1, afbeelding 2 van 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: stap 1, afbeelding 3 van 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: stap 2, afbeelding 1 van 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: stap 2, afbeelding 2 van 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: stap 2, afbeelding 3 van 3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: stap 3, afbeelding 3 van 3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Andrew Dippre
2.902 Reputatie
7 handleidingen geschreven
Clemson, Team 3-1, Benson Fall 2014 Lid van Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 6,443
