Ga door naar hoofdinhoud
Dell Inspiron 15-3521 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: stap 1, afbeelding 3 van 3
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: stap 2, afbeelding 1 van 3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: stap 2, afbeelding 2 van 3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: stap 2, afbeelding 3 van 3
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: stap 3, afbeelding 1 van 3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: stap 3, afbeelding 2 van 3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: stap 3, afbeelding 3 van 3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Andrew Dippre
2.902 Reputatie
7 handleidingen geschreven
Clemson, Team 3-1, Benson Fall 2014 Lid van Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Leden
9 handleidingen geschreven
Één opmerking
Awesome post. Thanks
Derek Morgan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 42
Altijd: 22,223
