Ga door naar hoofdinhoud
Dell Inspiron 15-3521 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: stap 1, afbeelding 3 van 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: stap 2, afbeelding 1 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: stap 2, afbeelding 2 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: stap 2, afbeelding 3 van 3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: stap 3, afbeelding 1 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: stap 3, afbeelding 2 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: stap 3, afbeelding 3 van 3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: stap 4, afbeelding 1 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: stap 4, afbeelding 2 van 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: stap 4, afbeelding 3 van 3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Andrew Dippre
2.902 Reputatie
7 handleidingen geschreven
Clemson, Team 3-1, Benson Fall 2014 Lid van Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 66
Altijd: 33,323
