Ga door naar hoofdinhoud
Dell Inspiron 15 N5040 Hard Drive Replacement
Wat je nodig hebt
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron 15 N5040 Hard Drive Replacement, Remove the Screws: stap 2, afbeelding 1 van 1
    • Remove the two screws from the computer base.
    How the f do you go from remove these two screws to oh look the back’s been removed? Looks like there’s a big chunk of instructions missing!
    Mark Phillips - Antwoord
  2. Dell Inspiron 15 N5040 Hard Drive Replacement, Sliding the Hard Drive: stap 3, afbeelding 1 van 1
    • Slide the hard drive to the right to disconnect it from the connector on the system board.
    Missing instructions on how to open case :(
    davidglynn - Antwoord
  3. Dell Inspiron 15 N5040 Hard Drive Replacement, Lifting the Hard Drive: stap 4, afbeelding 1 van 1
    • Lift the hard drive out of the computer base.
  4. Dell Inspiron 15 N5040 Hard Drive Replacement, Placing the Hard Drive: stap 5, afbeelding 1 van 1
    • Place the NEW hard drive on the computer base.
  5. Dell Inspiron 15 N5040 Hard Drive Replacement, Push the Hard Drive: stap 6, afbeelding 1 van 1
    • Push the hard drive towards the left to connect it to the connector on the system board.
  6. Dell Inspiron 15 N5040 Hard Drive Replacement, Replace the Screws: stap 7, afbeelding 1 van 1
    • Replace the two screws to the computer base.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Terrence15
79.091 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.985 handleidingen geschreven
Één opmerking
Hello thank you for the information take care all the best in the new year
Greg Weber - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,012
