Ga door naar hoofdinhoud
Dell Inspiron 15 7579 SSD M.2 Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 7579 SSD M.2 Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 SSD M.2 Drive Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15 7579 SSD M.2 Drive Replacement: stap 2, afbeelding 2 van 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 SSD M.2 Drive Replacement, SSD M.2 Drive: stap 3, afbeelding 1 van 1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  4. Dell Inspiron 15 7579 SSD M.2 Drive Replacement: stap 4, afbeelding 1 van 1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
Conclusie
Inaki Madrigal
730 Reputatie
6 handleidingen geschreven
Cal Poly, Team S24-G9, Maness Spring 2018 Lid van Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Leden
4 opmerkingen
I tried this, but the M.2 memory is not recognizable by the computer. Fortunately the computer was less than a year old so I was able to get free Dell service help.
Unfortunately, Dell said that this laptop had no options for upgrading the M.2 computer. It wa the same model number and I tried to put in Samsung NAND 970 EVO 500 GB. It did not recognize it.
Dell suggested I buy a new computer.
Any recommendations?
Robert - Antwoord
Hey, I actually made this guide. I’m sorry it didn’t work for you. I don’t think it’s right for you to have to purchase a new computer unless the M.2 port is damaged, in which repair really isn’t possible. I don’t really know what could have happened. Did the computer actually boot into the OS (operating system)?
Inaki Madrigal -
Can I upgrade the M2 card to NVME module? Technically the port are same. But have read on some forum it won’t recognized by the system.
Tharun George - Antwoord
It looks like the SSD I need to buy is a SATA drive with both the M key and B key, right? (not PCIe NVME or AHCI)
Getting the correct info from Dell is pointless. I’m looking at buying this 1TB to replace my existing 512GB drive.
https://www.amazon.com/Crucial-MX500-NAN...
Thanks!
Dennis Welch - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 44
Altijd: 4,051
