Ga door naar hoofdinhoud
Dell Inspiron 15 7579 RAM (Memory) Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 2, afbeelding 2 van 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): stap 3, afbeelding 1 van 1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 5, afbeelding 3 van 3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: stap 6, afbeelding 2 van 2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Conclusie
Inaki Madrigal
760 Reputatie
6 handleidingen geschreven
Cal Poly, Team S24-G9, Maness Spring 2018 Lid van Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 711
