Ga door naar hoofdinhoud
Dell Inspiron 15 7579 Motherboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 7579 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Motherboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15 7579 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Motherboard Replacement, Fan: stap 3, afbeelding 1 van 2 Dell Inspiron 15 7579 Motherboard Replacement, Fan: stap 3, afbeelding 2 van 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Motherboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15 7579 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Motherboard Replacement, SSD M.2 Drive: stap 6, afbeelding 1 van 1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 2 Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: stap 8, afbeelding 2 van 2
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Motherboard Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 15 7579 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 506
