Ga door naar hoofdinhoud
Dell Inspiron 15 7579 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Battery Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15 7579 Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Dell Inspiron 15 7579 Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
    Super easy 3minute battery swap, removing and replacing housing screws is what all the work here is.
    My Mom is super happy she no longer has to be plugged in to use her laptop.
    Thank you ifixit 😊✌️
    That1HippieChick - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
Inaki Madrigal
730 Reputatie
6 handleidingen geschreven
Cal Poly, Team S24-G9, Maness Spring 2018 Lid van Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Leden
2 opmerkingen
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - Antwoord
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 6,785
