Ga door naar hoofdinhoud
Dell Inspiron 15 7560 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 7560 Battery Replacement, Disconnect the Battery Cable: stap 1, afbeelding 1 van 1
  2. Dell Inspiron 15 7560 Battery Replacement, Peel the Tape: stap 2, afbeelding 1 van 1
    • Peel the tape that secures the hard-drive cable to the battery.
  3. Dell Inspiron 15 7560 Battery Replacement, Open the Latch: stap 3, afbeelding 1 van 1
    • Open the latch and disconnect the hard-drive cable from the system board.
  4. Dell Inspiron 15 7560 Battery Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 7560 Battery Replacement, Lifting the Battery: stap 5, afbeelding 1 van 1
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  6. Dell Inspiron 15 7560 Battery Replacement, Align the Screw Holes: stap 7, afbeelding 1 van 1
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Battery Replacement, Replace the Screws: stap 8, afbeelding 1 van 1
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 7560 Battery Replacement, Sliding the Hard Drive Cable: stap 9, afbeelding 1 van 1
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
  9. Dell Inspiron 15 7560 Battery Replacement, Adhering the Tape: stap 10, afbeelding 1 van 1
    • Adhere the tape that secures the hard-drive cable to the battery.
  10. Dell Inspiron 15 7560 Battery Replacement, Connect the Battery Cable: stap 11, afbeelding 1 van 1
    • Connect the battery cable to the system board.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Terrence15
79.585 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 4,696
