Ga door naar hoofdinhoud
Dell Inspiron 15 5577 Gaming Memory Modules Replacement
  1. Dell Inspiron 15 5577 Gaming Memory Modules Replacement, Popping up the Memory Module: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 5577 Gaming Memory Modules Replacement, Remove the Memory Module: stap 2, afbeelding 1 van 1
    • Remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  3. Dell Inspiron 15 5577 Gaming Memory Modules Replacement, Press the Memory Module Down: stap 4, afbeelding 1 van 1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 1,073
