Ga door naar hoofdinhoud
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: stap 1, afbeelding 1 van 1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: stap 3, afbeelding 1 van 1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
Conclusie
[deleted]
346 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 719
