Ga door naar hoofdinhoud
Dell Inspiron 15 5577 Gaming Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Disconnect the Display Cable: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Close the display and turn the computer over.
    • Using the pull tab, disconnect the display cable from the system board.
  2. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Noting the Display Cable: stap 2, afbeelding 1 van 1
    • Note the display-cable routing and remove the cable from the routing guides on the computer base.
  3. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Disconnecting the Antenna Cables: stap 3, afbeelding 1 van 1
    • Disconnect the antenna cables from the wireless card.
  4. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Note the Cable Routing: stap 4, afbeelding 1 van 1
    • Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Slide the Display Cable: stap 5, afbeelding 1 van 1
    • Slide the display cable and antenna cables through the slots on the computer base.
  6. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Remove the Screws: stap 6, afbeelding 1 van 1
    • Remove the four screws (M2x5) that secure the display assembly to the computer base.
  7. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Lifting the Display Assembly: stap 7, afbeelding 1 van 1
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Align the Screw Holes: stap 8, afbeelding 1 van 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Replace the Screws: stap 9, afbeelding 1 van 1
    • Replace the four screws (M2x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Sliding the Display Cable: stap 10, afbeelding 1 van 1
    • Slide the display cable and antenna cables through the slot on the computer base.
  11. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Routing the Display Cable: stap 11, afbeelding 1 van 1
    • Route the display cable and antenna cables through the routing guides on the computer base.
  12. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Connecting the Antenna Cables: stap 12, afbeelding 1 van 1
    • Connect the antenna cables to the wireless card.
  13. Dell Inspiron 15 5577 Gaming Display Assembly Replacement, Connecting the Display Cable: stap 13, afbeelding 1 van 1
    • Connect the display cable to the system board.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
Één opmerking
Note: This is a guide for replacing the entire display assembly, NOT just the display. If you are attempting to remove the display (like I was), gently snap off the display bezel, remove the four screws holding in the display, disconnect the display cable, connect the new display, screw it back in, and snap the display bezel back into place. Opening the bottom of the machine isn’t necessary.
Tech Saint - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 4,318
