Inleiding
In this guide, we will be showing you how to remove and replace the Battery.
Wat je nodig hebt
Remove the battery cable from the routing guides on the computer base.
Remove the five screws (M2x5 T8) that secure the battery to the computer base.
Using the pull tab, lift the battery, along with its cable, off the computer base.
Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the five screws (M2x5 T8) that secure the battery to the computer base.
Route the battery cable through the routing guides on the computer base.
3 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Please include a screwdriver valid for the M2x5 T8 battery screws under tools. Thanks.
