Inleiding
In this guide, you will learn to remove and replace the IO board on the Dell Inspiron 15 5565. Please see this page to perform troubleshooting steps.
Wat je nodig hebt
Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
