Ga door naar hoofdinhoud
Dell Inspiron 15 3593 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 15 3593 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15 3593 Battery Replacement: stap 2, afbeelding 2 van 2
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15 3593 Battery Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15 3593 Battery Replacement: stap 3, afbeelding 3 van 3
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15 3593 Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery out carefully and put the new battery in.
Conclusie
Reassemble the computer by following
the above steps in reversed order.
Abdul Obaid
169 Reputatie
1 Handleiding geschreven
2 opmerkingen
not all of the steps
there is somethings missing
aaaa2020 - Antwoord
So where is the rest of the story?
Jeanette Martinez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 88
Altijd: 2,685
