Inleiding
In this guide, we will be showing you how to remove and replace the Memory Modules.
Using your fingertips, pry apart the securing clips on each end of the memory-module slot until the memory module pops up.
Slide and remove the memory module from the memory-module slot.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
Bijna klaar!
Eindstreep
