Ga door naar hoofdinhoud
Dell Inspiron 15 3567 Memory Module Replacement
  1. Dell Inspiron 15 3567 Memory Module Replacement, Popping up the Memory Module: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Compter.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3567 Memory Module Replacement, Sliding the Memory Module: stap 2, afbeelding 1 van 1
    • Slide and remove the memory module from the memory-module slot
  3. Dell Inspiron 15 3567 Memory Module Replacement, Align the Notch: stap 3, afbeelding 1 van 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 3567 Memory Module Replacement, Installing the Memory Module: stap 4, afbeelding 1 van 1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 2,129
