Ga door naar hoofdinhoud
Dell Inspiron 15 3567 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 3567 Display Assembly Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Display Hinges: stap 2, afbeelding 1 van 1
    • Open the display hinges to an angle of 90 degrees.
  3. Dell Inspiron 15 3567 Display Assembly Replacement, Peel the Tape: stap 3, afbeelding 1 van 1
    • Peel the tape that secures the display cable to the palm-rest assembly.
  4. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Latch: stap 4, afbeelding 1 van 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Display Cable: stap 5, afbeelding 1 van 1
    • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
  6. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Antenna Cable: stap 6, afbeelding 1 van 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  7. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Palm Rest Assembly: stap 7, afbeelding 1 van 1
    • Open the palm-rest assembly at an angle and slide it off the display assembly.
  8. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Display Assembly: stap 8, afbeelding 1 van 1
    • Place the NEW display assembly on a clean, flat surface.
  9. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Palm-Rest Assembly: stap 9, afbeelding 1 van 1
    • Place the palm-rest assembly on the display assembly.
  10. Dell Inspiron 15 3567 Display Assembly Replacement, Close the Display Hinges: stap 10, afbeelding 1 van 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  11. Dell Inspiron 15 3567 Display Assembly Replacement, Replace the Screws: stap 11, afbeelding 1 van 1
    • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  12. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Antenna Cables: stap 12, afbeelding 1 van 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  13. Dell Inspiron 15 3567 Display Assembly Replacement, Connecting the Display Cable: stap 13, afbeelding 1 van 1
    • Connect the display cable and close the latch to secure the cable.
  14. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Display Cable: stap 14, afbeelding 1 van 1
    • Route the display cable through the routing guides on the palm-rest assembly.
  15. Dell Inspiron 15 3567 Display Assembly Replacement, Adhere the Tape: stap 15, afbeelding 1 van 1
    • Adhere the tape that secures the display cable to the palm-rest assembly.
    • Close the display and turn the computer over.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Terrence15
79.585 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 2,983
