Inleiding
In this guide, we will be showing you how to remove and replace the Hard Drive.
Wat je nodig hebt
Open the latch and disconnect the hard-drive cable from the system board.
Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Lift the hard-drive assembly off the palm-rest assembly.
Disconnect the interposer from the hard-drive assembly.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
Één andere persoon heeft deze handleiding voltooid.
