Ga door naar hoofdinhoud
Dell Inspiron 15 3559 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 3559 Display Assembly Replacement, Turn the Computer Over: stap 1, afbeelding 1 van 1
  2. Dell Inspiron 15 3559 Display Assembly Replacement, Noting the Cables: stap 2, afbeelding 1 van 2 Dell Inspiron 15 3559 Display Assembly Replacement, Noting the Cables: stap 2, afbeelding 2 van 2
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3559 Display Assembly Replacement, Note the Display Cable Routing: stap 3, afbeelding 1 van 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3559 Display Assembly Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3559 Display Assembly Replacement, Lifting the Display Assembly: stap 5, afbeelding 1 van 1
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3559 Display Assembly Replacement, Installing the new Display Assembly: stap 6, afbeelding 1 van 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3559 Display Assembly Replacement, Replace the Screws: stap 7, afbeelding 1 van 1
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3559 Display Assembly Replacement, Route the Display Cable: stap 8, afbeelding 1 van 2 Dell Inspiron 15 3559 Display Assembly Replacement, Route the Display Cable: stap 8, afbeelding 2 van 2
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3559 Display Assembly Replacement, Routing the Antenna Cables: stap 9, afbeelding 1 van 1
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 1,399
