Inleiding
This computer utilizes Skullcandy speakers that are located along the front of the laptop.
Wat je nodig hebt
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
Locate the black cord that was underneath the battery.
Carefully lift up the chip connected to the end of the cord on the daughter board.
Release the wire connecting the speakers from the securing clips by pulling them upward.
Één andere persoon heeft deze handleiding voltooid.
