Ga door naar hoofdinhoud
Dell Inspiron 14z-5423 Optical Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 14z-5423 Optical Drive Replacement, RAM: stap 1, afbeelding 1 van 2 Dell Inspiron 14z-5423 Optical Drive Replacement, RAM: stap 1, afbeelding 2 van 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Optical Drive Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 14z-5423 Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Optical Drive Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 14z-5423 Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Optical Drive Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 14z-5423 Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Optical Drive Replacement, Optical Drive: stap 6, afbeelding 1 van 2 Dell Inspiron 14z-5423 Optical Drive Replacement, Optical Drive: stap 6, afbeelding 2 van 2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
Conclusie
Marisol
623 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team 2-2, Bruce Fall 2016 Lid van CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 672
