Ga door naar hoofdinhoud
Dell Inspiron 14z-5423 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: stap 1, afbeelding 1 van 2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: stap 1, afbeelding 2 van 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 14z-5423 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 14z-5423 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 14z-5423 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: stap 6, afbeelding 1 van 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: stap 6, afbeelding 2 van 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: stap 6, afbeelding 3 van 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 14z-5423 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 14z-5423 Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: stap 10, afbeelding 1 van 3 Dell Inspiron 14z-5423 Keyboard Replacement: stap 10, afbeelding 2 van 3 Dell Inspiron 14z-5423 Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Conclusie
Marisol
623 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team 2-2, Bruce Fall 2016 Lid van CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 1,498
