Ga door naar hoofdinhoud
Dell Inspiron 14z 1470 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: stap 1, afbeelding 1 van 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: stap 1, afbeelding 2 van 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Dell Inspiron 14z 1470 Display Assembly Replacement, Disconnecting the Display Cable: stap 2, afbeelding 1 van 1
    • Disconnect the display cable and remove the screw from the system board.
  3. Dell Inspiron 14z 1470 Display Assembly Replacement, Pull the Antenna Cables: stap 3, afbeelding 1 van 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 14z 1470 Display Assembly Replacement, Note the Routing: stap 4, afbeelding 1 van 1
    • Note the routing of all the cables and remove them from their routing guides.
  5. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: stap 5, afbeelding 1 van 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: stap 5, afbeelding 2 van 2
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
  6. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display Assembly: stap 6, afbeelding 1 van 1
    • Lift and remove the display assembly from the computer base.
  7. Dell Inspiron 14z 1470 Display Assembly Replacement, Place the Display Assembly: stap 7, afbeelding 1 van 1
    • Using the alignment posts, place the NEW display assembly in position and replace the three screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14z 1470 Display Assembly Replacement, Routing the Antenna Cables: stap 8, afbeelding 1 van 1
    • Route the Mini-Card antenna cables and display cable through their routing guides.
  9. Dell Inspiron 14z 1470 Display Assembly Replacement, Route the Antenna Cables: stap 9, afbeelding 1 van 1
    • Route the antenna cables through the slot in the computer base.
  10. Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: stap 10, afbeelding 1 van 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: stap 10, afbeelding 2 van 2
    • Replace the screw and connect the display cable.
Eindstreep
Terrence15
79.585 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 268
