Ga door naar hoofdinhoud
Dell Inspiron 14R-5421 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 14R-5421 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
Conclusie
Jared paiva
489 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S4-G4, Covino Spring 2018 Lid van UMass Dartmouth, Team S4-G4, Covino Spring 2018
UMASSD-COVINO-S18S4G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 551
