Ga door naar hoofdinhoud
Dell Inspiron 1440 Speaker Replacement
Wat je nodig hebt
  1. Dell Inspiron 1440 Speaker Replacement, Keyboard: stap 1, afbeelding 1 van 2 Dell Inspiron 1440 Speaker Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Dell Inspiron 1440 Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that are surrounding and underneath the middle plate.
  5. Dell Inspiron 1440 Speaker Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 1440 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 Speaker Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 1440 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 Speaker Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 1440 Speaker Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 1440 Speaker Replacement: stap 7, afbeelding 3 van 3
    • Remove the 4 mm screws on either end of each speaker. Once they are removed, pull up the speaker.
Conclusie
Tyler Lyons
452 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 Lid van UMass Dartmouth, Team S1-G3, Barthe Fall 2019
UMASSD-BARTHE-F19S1G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 421
