Ga door naar hoofdinhoud
Dell Inspiron 1440 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 1440 Display Assembly Replacement, Remove the Screws: stap 1, afbeelding 1 van 2 Dell Inspiron 1440 Display Assembly Replacement, Remove the Screws: stap 1, afbeelding 2 van 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws from the computer base.
  2. Dell Inspiron 1440 Display Assembly Replacement, Disconnecting the Camera Cable: stap 2, afbeelding 1 van 1
    • Disconnect the camera cable from the system board connector.
  3. Dell Inspiron 1440 Display Assembly Replacement, Removing the Cables: stap 3, afbeelding 1 van 1
    • Make note of the Mini-Card antenna cables, camera cable, and the display cable routing and remove the cables from their routing guides.
  4. Dell Inspiron 1440 Display Assembly Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 1440 Display Assembly Replacement, Removing the Display Assembly: stap 5, afbeelding 1 van 1
    • Lift and remove the display assembly from the computer base.
  6. Dell Inspiron 1440 Display Assembly Replacement, Placing the Display Assembly: stap 6, afbeelding 1 van 1
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1440 Display Assembly Replacement, Routing the Cables: stap 7, afbeelding 1 van 1
    • Route the Mini-Card antenna cables, camera cable, and display cable through the routing guides.
  8. Dell Inspiron 1440 Display Assembly Replacement, Connecting the Camera Cable: stap 8, afbeelding 1 van 1
    • Connect the camera cable to the system board connector.
  9. Dell Inspiron 1440 Display Assembly Replacement, Replace the Screws: stap 9, afbeelding 1 van 2 Dell Inspiron 1440 Display Assembly Replacement, Replace the Screws: stap 9, afbeelding 2 van 2
    • Replace the two screws at the bottom of the computer.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
Één opmerking
Se puede upgradear la pantalla de esta laptop por una mejor ya sea un panel FHD IPS o no? Existe alguna compatibilidad para poder hacer un upgrade de pantalla? muchas gracias
djshebanana - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 535
