Ga door naar hoofdinhoud
Dell Inspiron 1428 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive cover to the computer base.
  2. Dell Inspiron 1428 Hard Drive Replacement, Pry out te Hard-Drive Cover: stap 2, afbeelding 1 van 1
    • Pry out the hard-drive cover using your finger.
  3. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: stap 3, afbeelding 1 van 1
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  4. Dell Inspiron 1428 Hard Drive Replacement, Disconnecting the Hard Drive Assembly: stap 4, afbeelding 1 van 1
    • Pull the pull-tab on the hard-drive assembly towards the right to disconnect the hard-drive assembly from the system board connector.
  5. Dell Inspiron 1428 Hard Drive Replacement, Lifting the Hard-Drive Assembly: stap 5, afbeelding 1 van 1
    • Lift the hard-drive assembly out of the computer base.
  6. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: stap 6, afbeelding 1 van 1
    • Remove the four screws that secure the hard drive to the hard-drive cage.
  7. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard Drive: stap 7, afbeelding 1 van 1
    • Place the NEW hard drive in the hard-drive cage.
  8. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: stap 8, afbeelding 1 van 1
    • Replace the four screws that secure the hard drive to the hard-drive cage.
  9. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard-Drive Assembly: stap 9, afbeelding 1 van 1
    • Place the NEW hard-drive assembly in the computer base.
  10. Dell Inspiron 1428 Hard Drive Replacement, Connecting the Hard-Drive Assembly: stap 10, afbeelding 1 van 1
    • Slide and connect the hard-drive assembly to the system board connector.
  11. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: stap 11, afbeelding 1 van 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 1428 Hard Drive Replacement, Align the Tabs: stap 12, afbeelding 1 van 1
    • Align the tabs on the hard-drive cover with the slots on the computer base and snap the hard-drive cover into place.
  13. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: stap 13, afbeelding 1 van 1
    • Replace the two screws that secure the hard-drive cover to the computer base.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 83
