Inleiding
In this guide, we will be showing you how to remove and replace the Display Assembly.
Wat je nodig hebt
Make note of the Mini-Card antenna cables routing and remove the cables from the routing guides.
Remove the four screws that secure the display assembly to the computer base.
Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
Disconnect the display cable, inverter board cable, camera cable, and microphone cables from the respective system board connectors.
Remove the two screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
Connect the display cable, inverter board cable, and the camera cable to their respective system board connectors.
