Inleiding
In this guide, we will be showing you how to remove and replace the Hard Drive Assembly.
Wat je nodig hebt
Remove the screw that secures the hard-drive assembly to the system board.
Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Place the NEW hard-drive assembly on the system board.
Slide the hard-drive assembly to connect it to the connector on the system board.
Replace the screw that secures the hard-drive assembly to the system board.
